How to remove the alternator from a vz?
ANONYMOUS
  • 2004 HOLDEN COMMODORE
Friday, December 28th, 2012 AT 2:55 AM
  • 31,937 POSTS
Battery disconnected, make sure you have the radio security code, remove serpentine belt, there are 2 bolts holding the alternator in place no adjustment bolt, remove and disconnect main wire and secondary loom plug.
Here is a guide to help you get an idea on what you are in for.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Monday, December 31st, 2012 AT 2:58 PM
JET
  • 1997 HOLDEN COMMODORE
Electrical problem
1997 Holden Commodore 6 cyl Two Wheel Drive Automatic
Hi there, can someone please give me a bit of a walkthrough for changing the alternator on a 1997 VT commodore.
I've done many before but not on this model car, it appears to have a spring loaded type assembly for the serpentine belt tensioner and I don't want stuff this up.
Your help is greatly appreciated.
Jet Manning
Wednesday, March 22nd, 2017 AT 10:43 PM (Merged)
  • 31,937 POSTS
Hi there,
Place a socket and bar on the tensioner pulley center bolt, pull back on the tensioner and flick the belt off, make a drawing first of the way it goes, otherwise you will be back here wanting that info as well, rake off the battery terminal and remove the 2 supporting bolts and wires for the alt, make sure that the main cable to the alternator is not burnt or badly corrodes as this is a problem with them.
Mark (mhpautos)
