Windshield wipers do not work all the time. Is that common with this truck and is their a fix?
Tuesday, November 16th, 2010 AT 2:40 PM
MECHANIC
It is not a common problem. When they do not work, have you checked to see if there is power to the motor?
SPONSORED LINKS
Tuesday, November 16th, 2010 AT 2:41 PM
MMPRINCE4000
MECHANIC
Could be the wiper transmission is binding or switch is bad.
During one of these events (wipers not working), disconnect wiper motor connector and check for twelve volts, if twelve volts is read, then binding or a bad motor, if no voltage, then switch.
Tuesday, November 16th, 2010 AT 2:44 PM
MIKENEUMANN1
MEMBER
I can hear some thing trying to work like a motor humming.
Plus the fluid sprayer does not work.
Tuesday, November 16th, 2010 AT 2:55 PM
EMMAI
MEMBER
1 POST
1993 GMC SUBURBAN
6 CYL
4WD
AUTOMATIC
150,000 MILES
Six cylinder four wheel drive automatic 150,000 miles
My wipers do not work. When you turn them on they make a whirring noise. They were working, but it would take a while from them to start working after you turned them on. Now they are not working at all.
Wednesday, January 4th, 2017 AT 4:14 PM
(Merged)
WRENCHTECH
MECHANIC
If you are hearing a whirring noise then there is something stripped or broken at the motor. You will have to remove the motor for inspection. It may be internal plastic gears stripped or the linkage could have come apart inside the cowl area.
SPONSORED LINKS
(Merged)
TOPCAT
MEMBER
1998 GMC SUBURBAN
Wipers do not work.
(Merged)
BMRFIXIT
MECHANIC
First check fuses,
Second check motor ground.
Third check for power at the wiper motor.
If you have power and ground suspect bad motor.
