Intake manifold torque specs
ROBERT GREEN
  • 2006 FORD TAURUS
  • 3.0L
  • 188,961 MILES
Lower intake manifold torque specs.
Tuesday, October 18th, 2016 AT 1:24 PM
HMAC300
  • 48,601 POSTS
Tighten in sequence stage 1-11 lbs stage 2-24 lb.
Tuesday, October 18th, 2016 AT 4:42 PM
ROBERT GREEN
Thank you, I thought so.
Tuesday, October 18th, 2016 AT 10:50 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,047 POSTS
Nice work Hmac300 great answer
Wednesday, October 19th, 2016 AT 9:35 PM
D-BARRON
  • 2003 FORD TAURUS
What would be the torque for the intake manifold bolts
Wednesday, February 3rd, 2021 AT 4:00 PM (Merged)
SCOTTY DEE
  • 592 POSTS
Upper Intake- torque at 10 Nm (89 in. Lbs.). Work from the center out.
Lower Intake
Stage 1: Tighten to 15 Nm (11 ft. Lbs.).
Stage 2: Tighten to 32 Nm (24 ft. Lbs.).
AQUARIUM123
  • 2002 FORD TAURUS
  • 4 CYL
  • 89,000 MILES
I need the torque & sequence for the upper intake manifold for my 3.0 dual Overhead Cam- Plastic Manifold with 8 bolts?
Wednesday, February 3rd, 2021 AT 4:01 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
This is what i have hope that help
https://www.2carpros.com/forum/automotive_pictures/99387_30taurus_1.jpg
good luck
AQUARIUM123
I appreciate your time.
FITZ04
  • 2000 FORD TAURUS
Engine Mechanical problem
2000 Ford Taurus 6 cyl Two Wheel Drive Automatic
need toqure specs and sequence to tighten manifold
DAVE H
  • 13,383 POSTS
3.8L
Upper Intake Manifold Bolt...............Lbs. Nm.
1st Step........................................53.. (6)
2nd Step.......................................70 ..(8
3rd Step..............................Additional 90 Degrees
https://www.2carpros.com/forum/automotive_pictures/266999_man_1.jpg
FITZ04
Thanks for the reply but this is not the type of maniford that i have, after looking at the engine this morning it is a Duratec 24 valve v6, it has 8 bolts. my fault i did not say what engine i had
https://www.2carpros.com/forum/automotive_pictures/317531_002_2.jpg
DAVE H
  • 13,383 POSTS
Intake Manifold Bolt (Upper And Lower) Lbs89 Nm(10)
https://www.2carpros.com/forum/automotive_pictures/266999_upper_1.jpg
FITZ04
That is it thankyou very mutch can you tell me what book you got this from as I have looke all over for a book Hanes, Chileton none of them have it
what do people normally domate for answers as I would like to as it helped me a lot thanks again
DAVE H
  • 13,383 POSTS
Glad to be of assistance. The diagram is from an online (internet) website that supplies manuals called mitchell1. There is a link at the bottom of this reply box. Donotions are not set. If you feel our help was worth $5/15/20 then donate that amount, if you feel it was worth $1 then donate that amount. All donations are very much appreciated. Please feel free to leave feedback as well using the link at the top of this reply. Please use our services again and spread the word of our services
Happy motoring
Dave H
