Anti-theft problem
PASSAMA
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 92,348 MILES
I put a new battery in the car today and now it won't start I think it is the anti-theft because the light flashes when I try to start it I was just wondering if there is a way to deactivate it so I can start the car to sell it.
Tuesday, November 3rd, 2009 AT 9:59 PM
BMRFIXIT
  • 19,053 POSTS
Use the key lock and unlock the door or trunk
use the fob to deactivate the alarm if have one
check driver side under steering area for a small after market add on switch
if found turn key on and cycle the switch them start
also you can try this open a window
remover negative side of battery step on the brakes
place key in ignition and turn it on
place negative cable back
start the engine
Wednesday, November 4th, 2009 AT 6:04 AM
BLKSTALLION575
  • 2002 FORD TAURUS
  • 6 CYL
I have a 2002 Ford Taurus. The anti theft is malfunctioning. Most of the time I'm unable to start my car. And when I'm able to it sometimes it shuts down a few seconds after starting, and then it may be days before I can start it again. Or I end up being stranded somewhere. Is there a way that I can deactivate it?
Wednesday, October 31st, 2018 AT 11:44 AM (Merged)
  • 108,192 POSTS
It cant be bypassed it sounds like the GEM is out and needs to be replaced here is the location. Check out the diagrams (Below). Please let us know what happens.
KOCH
  • 2002 FORD TAURUS
  • V6
  • 50,000 MILES
The anti theft light blinks when the car is turned off it does go out when car is turned on and the car runs fine but I just wanted to know if this was normal and if it would drain the battery?
HMAC300
  • 48,601 POSTS
Try resetting it it may take care of it other wise it will need to be scanned to see what is wrong with system. If no manual look online on how to reset it
MARILYNDIETZ
  • 2002 FORD TAURUS
  • FWD
  • 205,000 MILES
My 2002 ford taurus won't start and the "theft" light is flashing @ about 3X per second. What's going on? Also, I ahd the starter checked and it was bad. I've installed a new starter and I have power at the starter but no power at the soliniod when the the key is turned.
FIXITMR
  • 9,990 POSTS
So which came first? The bad starter or the anti theft light?
RORO
  • 2002 FORD TAURUS
I have a 2002 Ford Taurus, SEL with 60000 miles with DOH V6 larger engine.
The blower motor was replaced yesterday, seems to work fine now.
Car was driven during the day about 10 miles.
Later car was completely dead but the theft light was clicking and blinking very rapidly and the ABS light was a faint steady glow.
I think that the battery needs replacement, that does make sense?
FIXITMR
  • 9,990 POSTS
While that does make sense as far as getting power back it may not work, and if it does in the short term, it may not in the long term, say overnight? I would take the current battery in to the parts place and have it tested.
COLE2002TAURUS
  • 2002 FORD TAURUS
Electrical problem
2002 Ford Taurus 6 cyl Front Wheel Drive Automatic
My engine is stalling while driving and the "Theft" light comes on. It starts right back up.
BMRFIXIT
  • 19,053 POSTS
Best way to go about it is to check for codes
use a scanner tools
2CP-ARCHIVES
  • 4,542 POSTS
  • 2002 FORD TAURUS
What causes the car to cut out all power when I'm driving which makes my anti theft system lock up my car. Please help
  • 52,797 POSTS
Start with battery and alternator check.
MARILYNDIETZ
  • 2002 FORD TAURUS
  • FWD
  • 205,000 MILES
My 2002 ford taurus won't start and the "theft" light is flashing @ about 3X per second. What's going on? I had the starter tested, it was bad and I have installed a remanufactured unit. I have ower at the starter but no power to the soliniod when the key is turned.
  • 108,192 POSTS
You need to have it diagnosed at a dealer. They are the only ones with the proper test equipment to check it.
JIMMYBOB
  • 2004 FORD TAURUS
  • 6 CYL
  • 75,000 MILES
We were driving home on the highway and the theft light came on for about 5 seconds and then we lost a little power. Then about 5 minutes later, it did the same thing, only that time, the fuel light also came on with the theft light. And we lost a little power then too. It always seemed to go off after about 3 -5 seconds, but I was wondering what might be causing this.
P.S. We had about more than a 1/4 tank of gas, so I figure that can't be it. THanks!
BMRFIXIT
  • 19,053 POSTS
Possible key and or ignition switch
should have it checked
EMILIT
  • 2000 FORD TAURUS
  • 6 CYL
  • 4WD
  • 94,741 MILES
Merlin 2021 helped with this back in June. While driving my theft light comes on if I notice and accelerate then car does not stall. But if I miss it car stalls. I also have trouble starting it sometimes. I turn the key up to 20 times before it starts. I've had the starter, battery, ignition switch replaced and the fuel injection flushed. But I still have problems. Also, a PCV was replaced for the stalling.
Now if I get it to start it stalls soon afterward.
I was told to check the plastic switch part not the key.
I jiggled where the key goes in and I didn't have the problem for 3 months.
Where is the plastic switch part that needs checked?
BMRFIXIT
  • 19,053 POSTS
From the sound of it the problem is in the key
dealer is your only help for a new key ___
inside that plastic cover on the key you have a transponder
and that's what enable the security system
I would make sure I have nothing electronic or magnetic on or with the ignition key
(Mobil speed pass and so on...)
if you have an after market remote starter
same will happen too
also you can have it scanned as it has a self diagnostic system
and you can retrieve codes that will help pin pointing the issue
good luck
CARMENNL
  • 22 POSTS
  • 2000 FORD TAURUS
  • 6 CYL
  • 200,000 MILES
I would like tyo know whats the problem. The theft lights comes on and the odometer gets unstable. Car dies. What is it what do I need to do to get this fixed. Thank you
