1998 Ford Taurus will not Move from the parking position t
JOSE MUNIZ
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 45,000 MILES
Many parts have been replace but the problem persist
Tuesday, November 2nd, 2010 AT 3:38 PM
  • 110,194 POSTS
Is the shifter the problem, or is it moving? Are the brake lights working?
Tuesday, November 2nd, 2010 AT 7:50 PM
JOSE MUNIZ
  • 5 POSTS
The shifter is no moving
Tuesday, November 2nd, 2010 AT 9:03 PM
  • 110,194 POSTS
Tuesday, November 2nd, 2010 AT 9:26 PM
JOSE MUNIZ
  • 5 POSTS
Brake lights don't work
Wednesday, November 3rd, 2010 AT 1:45 PM
  • 110,194 POSTS
Replace the brake light switch (or adjust). It could be unplugged too. It is located at the top of the brake pedal under the dash. When you touch the brake, the switch turns on the lights and sends power to the park lock solenoid which allows you to shift from park. If the brake light switch isn't working, you will not be able to shift from park.
Let me know what you find.
Wednesday, November 3rd, 2010 AT 1:50 PM
JOSE MUNIZ
  • 5 POSTS
Brake light switch seems to be OK. Check with meter and it reads continuity. Cable that connects to switch has voltage. Bulbs are OK. Fuses look good
Wednesday, November 3rd, 2010 AT 5:07 PM
  • 110,194 POSTS
You mentioned the brake lights don't work. Is that correct? If they are not working, there is either a wiring issue between the switch and the bulbs, or there could be power to the switch but not power out from it. Have you checked that?
Thursday, November 4th, 2010 AT 7:28 AM
52D
  • 18 POSTS
It's a fuze, beilive it or not Ford put a eletric lock on the park lock. If it's the same fuze as my ranger, it number 13 in the box. Replace it and you should be fine
note : some cars have as many as 6 fuzeboxes in different places all across the car.
Thursday, November 4th, 2010 AT 9:45 AM
JOSE MUNIZ
  • 5 POSTS
My friends, thank you very much for your valuable help. I was able to fix my car and save a lot of money. My problem was the stop light switch. It is necessary to get it out from under the hood in order to make a good inspection. The small metal clamp didn't work but I was able to fix it with four small plastic straps replacing metal clamp. I'm forwarding your site to all my friends.
Friday, November 5th, 2010 AT 12:49 PM
Related General Content
