Other Category problem
1997 Ford Taurus V6 Two Wheel Drive 95000 miles
Is there a sort cut on taking the heater out with out removing all of the dash
Thursday, December 6th, 2007 AT 11:14 PM
CARDRIVER314
MEMBER
Friday, December 7th, 2007 AT 7:59 AM
CARDRIVER314
MEMBER
I do not have any heat at idle only when driving what could be the problem. I have changed the thermostat and flushed the system and the water pump has been changed also
Tuesday, December 11th, 2007 AT 11:32 AM
HOYDENISH
MEMBER
1 POST
Yes, I do have orange/brown coolant and no heat in the cabin. I have the car diagnosed by pepboys and was told that I need to replace the heater core and water pump. It is more than thousand dollars. Is there any way to reduce the cost to repair it?
