1994 Ford Ranger Ignition Lock
DEAFREV
  • 1994 FORD RANGER
  • 6 CYL
  • 112,000 MILES
My ignition lock needs to be replaced. How do I go about doing this?
Thanks!
Deafrev in Fresno
Do you
have the same problem?
Monday, April 13th, 2009 AT 4:06 PM
BLUELIGHTNIN6
  • EXPERT
REMOVAL:
Disconnect the negative battery cable. Remove the steering wheel.
On vehicles equipped with tilt wheel, remove the tilt lever.
On vehicles equipped with tilt wheel, remove the steering column collar by pressing on the collar from the top and bottom while removing the collar.
Remove the instrument panel trim cover retaining screws. Remove the trim cover.
Remove the 2 screws from the bottom of the steering column shroud. Remove the bottom half of the shroud by pulling the shroud down and toward the rear of the vehicle.
Turn the lock cylinder with the ignition key in it to the ON position. On vehicles equipped with automatic transmission be sure that the selector lever is in the P position.
Push up on the lock cylinder retaining pin with a 1 / 8 in. (3mm) diameter wire pin or small punch. Pull the lock cylinder from the column housing. Disconnect the lock cylinder wiring plug from the horn brush wiring connector.
http://www.2carpros.com/forum/automotive_pictures/261618_0900c1528018f1e7_4.jpg
INSTALLATION:
Prior to installation of the lock cylinder, lubricate the cylinder cavity, including the drive gear, with Lubriplate or equivalent.
To install the lock cylinder, turn the lock cylinder to the ON position, depress the retaining pin. Insert the lock cylinder housing into its housing in the flange casting. Be sure that the tab at the end of the cylinder aligns with the slot in the ignition drive gear.
Turn the key to the OFF position. This action will permit the cylinder retaining pin to extend into the cylinder casting housing hole.
Using the ignition key rotate the lock cylinder to ensure correct mechanical operation in all positions. Connect the key warning wire plug.
Install the steering column lower shroud. Install the steering wheel.
Check for proper vehicle operation in P and N . Also be sure that the start circuit cannot be actuated in D or R .
STEERING WHEEL REMOVAL/INSTALLATION:
Center the steering wheel to the straight ahead position.
From the underside of the steering wheel, remove the screws that hold the steering wheel pad to the steering wheel spokes.
Lift up the steering wheel pad and disconnect the horn wires from the steering wheel pad by pulling the spade terminal from the blade connectors.
Remove the steering wheel pad. Loosen the bolt 2 or 3 turns from the steering shaft.
CAUTION
Tilt columns have a compression spring under the steering wheel that can unexpectantly "pop up" the steering wheel if the bolt is removed completely.
Using the proper steering wheel removal tool, loosen the steering wheel on the steering column.
WARNING
Do not hammer on the steering wheel or the steering shaft or use a knock off type steering wheel puller as damage to the steering column will occur.
Remove the tool and the steering wheel retaining bolt then lift off the steering wheel.
Installation is the reverse of the removal procedure. Be sure that the steering wheel is properly aligned before installing the lock bolt. Torque the steering wheel lock bolt to 23-33 ft. lbs. (31-45 Nm).
Thanks for using 2CarPros.com!
Monday, April 13th, 2009 AT 4:32 PM
DEAFREV
Must the steering wheel be removed for this project?
Tuesday, April 14th, 2009 AT 5:42 PM
BLUELIGHTNIN6
  • EXPERT
Yes, for your vehicle the steering wheel needs removed as mentioned above to replace your vehicle's ignition lock cylinder.
Thanks for using 2CarPros. Com!
Tuesday, April 14th, 2009 AT 6:19 PM
Recommended Guides
