Focus 2002, high RPM no shifting into overdrive on automatic
2002 FORD FOCUS
SBUDCO
I have a problem where the engine RPMs would jump high and the car wouldn't accelerate. Looks like it's shifting fine first 3 gears, and won't go to 4th or overdrive. RPM goes very high, but the car won't shift the gear.
If i drive with overdrive off all shifting is fine, but i can't really go over 80km/h or so.
I have 145 000 km and not sure if it's a simple problem or something more complex.
One of the tech described problem as "shift solenoid A failure" please help.
Ford Focus SE ztec engine.
Feb 22, 2006 at 6:00 PM
TIML
  • 19 POSTS
have you tried scanning for codes.might be a good start.at least it gies you a starting point.
Feb 25, 2006 at 3:05 PM
