Saturday, November 22nd, 2008 AT 4:22 PM
No heat and overheating. I replaced the t stat and now does not overheat but still no heat. Flushed heater core and still only 1 hose gets hot. Did not find any leaks could core still be bad or what else can I try. And I let truck run for about 30 min with radiator cap off to bleed air from system. Thank you for your help
