Sunday, August 29th, 2010 AT 10:47 PM
I think the answer is simple. I had some issues with my oil pressure and you guys gave me good advice which worked fine. Now my idle is acting up. It will start perfect and run. After a few minutes or so the idle will drop down from its cold start and then down more. When it gets to it leveling off rpm it goes down to barely running then at the last second it saves itself. Then it will do it again. And finally it just dies. I can start right back up again. I removed and cleaned the idle control vavle and it was fairly dirty but still same result. Is that even possible to clean and second my thoughts were maybe throtlle position sensor. Side note- when I drive it and it doesnt die it has a little hesitation and sometimes it just ramps up like nothing is wrong.
