1994 Ford F-150
LEIF.THE.DRUMMER
  • 1994 FORD F-150
Transmission problem
1994 Ford F150 6 cyl Two Wheel Drive Manual
My 1994 F150 was running fine until the weather turned cold. One morning I was attempting to leave work and my clutch pedal lost pressure and went straight to the floor. There are no leaks that I can find, but it still wont build pressure. I asked a couple of people and some said that its the master slave, my uncle who is a trusted mechanic said that it is more than likely the master cylinder, but both aren't cheap and the slave definitely isn't easy. Just wanted to know what you all thought! I have attempted to bleed the system and I haven't had to replace any fluid. Could it just be that the master cylinder is bad. Or could it be a massive air bubble in the system?
Sunday, March 14th, 2010 AT 8:00 AM
  • 110,192 POSTS
I think they are both correct. I believe they are refering to the same thing. The slave cylender (master clender) will do this.
Sunday, March 14th, 2010 AT 9:06 PM
LEIF.THE.DRUMMER
That is not true through. The Clutch slave cylinder operates the clutch hydraulically. The Clutch master cylinder is what builds the pressure for the slave cylinder to operate.
Monday, March 15th, 2010 AT 12:54 AM
  • 110,192 POSTS
That is correct. Maybe I worded it incorrectly. They both could be right. However, my first guess is the master cylender unless you have seen a leak.
Monday, March 15th, 2010 AT 8:00 AM
Related General Content
