1992 Ford F150 alterantor
1992 FORD F-150
17,767 MILES • V8 • 2WD • AUTOMATIC
DONSTYERS
i replace the alt today and a new battery and cerpenteen belt still low volt like 6volt at the batter what could be the proplem the battery light stays onn now didnt befor
Dec 15, 2008 at 7:14 PM
DAVE H
  • CERTIFIED EXPERT
  • 13,384 POSTS
check belt tension and all wiring connections >
Alternator Light Stays On With Engine Running
Loose or worn alternator drive belt....Check alternator drive tension and condition,
Loose alternator wiring connections...Check all charging system connections
Short in alternator light wiring
Defective alternator stator or diodes.....See Bench Tests in ALTERNATOR article
Defective regulator....See Regulator Check in ALTERNATOR article
Dec 15, 2008 at 7:59 PM
