1991 Ford F-150
JOE TOBIN
  • 1991 FORD F-150
  • V8
  • 132,000 MILES
The battery got hooked up backwards with the key on and burned a piece of wire to the alternator. Now it turns over and won't start. All the fuse links are good. What should I be looking at or for?
Friday, March 12th, 2010 AT 3:07 PM
  • 110,182 POSTS
Was the wire that burned a fuseable link?
Saturday, March 13th, 2010 AT 5:11 PM
JOE TOBIN
Saturday, March 13th, 2010 AT 11:39 PM
  • 110,182 POSTS
Which is missing, spark or fuel?
Sunday, March 14th, 2010 AT 4:32 PM
JOE TOBIN
I changed the tfi and got it started. The problem now seems to be fuel. Some one dumped urine in the tank. Thank you for your help.
Sunday, March 14th, 2010 AT 4:55 PM
  • 110,182 POSTS
Joe:
I can't believe it. If you replaced the TBI and it's running, make sure to dump the fuel in the tank, fuel line, replace the filter, clean the fuel rail. Or you will end up with the same problem.
If you have other questions, let me know.
Sunday, March 14th, 2010 AT 8:54 PM
JOE TOBIN
Thank you again for the help. I really thought the computer was gone but on a whim I replaced the TFI and it started. I understand about the fuel tank, lines and rail. If I disconect the fuel return line, this will purge the rail, correct?
Sunday, March 14th, 2010 AT 10:02 PM
  • 110,182 POSTS
It should take care of it for you. And don't worry, what goes around comes around. Whoever did it will have his day. Sick people. Life isn't already hard enough.
Sunday, March 14th, 2010 AT 11:22 PM
JOE TOBIN
Again, thank you for your help (:
Monday, March 15th, 2010 AT 12:40 AM
  • 110,182 POSTS
You are very welcome.
Monday, March 15th, 2010 AT 7:56 AM
Related General Content
