HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Warning Lights
Check Engine Light
1998 Ford Explorer check engine light
SUPERVISOR7210
MEMBER
1998 FORD EXPLORER
V8
AWD
AUTOMATIC
121,000 MILES
VCheck engine light will not come on when the ignition is turned on and it will not pass emissions test
Monday, January 7th, 2008 AT 12:51 PM
2CARPRO JACK
MECHANIC
Check/change bulb in dash
Monday, January 7th, 2008 AT 2:36 PM
Please
login
or
register
to post a reply.
Related Check Engine Light Content
The Check Engine Light Came On And Started Blinking
The Car Acts Like Its Going To Stall Out. Won't Pick Up Speed Easily. The Check Engine Light Came On And Started Blinking. The Engine...
Asked by
tea1970
1998
FORD EXPLORER
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
Check Engine Light 1998 Ford Explorer
1998 Ford Explorer Check Engine Light Is On. The Codes Are Po171 & Po174 Bank 1 And Bank 2 Too Lean. I've Changed The Mass Air Flow Sensor...
Asked by
dc9595
1998
FORD EXPLORER
Failed Inspection Because Check Engine Does Not Come On When You Turn The Ignition On
Asked by
supervisor7210
1 ANSWER
1998
FORD EXPLORER
Service Engine Light On Ford E-250 5.4?
What Would Cause The "service Engine Light' To Continue To Be On? I Ran A Obd Code Retreival And It Came Up " Bank 2 Too Lean" I Put All New...
Asked by
ross garlar
1998
FORD EXPLORER
1998 Ford Explorer Advice
I Just Brought A Used 1998 Ford Explorer Sport. My Check Engine Light Is On, It Takes A Long Time To Gain Speed. Especially Up Hills. When...
Asked by
April03
1998
FORD EXPLORER
VIEW MORE
Code Read Retrieval/Clear - Dodge Stratus
Code Read Retrieval/Clear Mercedes-Benz C230
Check Engine Light Safe to Drive?
