Need detailed instructions on how to remove and replace an oil pump in the car listed above (ZX2).
Saturday, March 3rd, 2018 AT 5:22 PM
HARRY P
MECHANIC
I am attaching the complete guide from Mitchell1's Prodemand. This is a fairly involved job. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Good luck.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, March 4th, 2018 AT 4:49 AM
BADGER21
MEMBER
1 POST
2000 FORD ESCORT
Engine Mechanical problem
2000 Ford Escort 4 cyl Manual
HOW DO YOU CHANGE AN OIL PUMP ON THE CAR
Saturday, October 10th, 2020 AT 9:37 AM
(Merged)
MECHANIC
Hi there oil pump information see text and pics.
Mark (mhpautos)
(Merged)
MOWENS1
MEMBER
1998 FORD ESCORT
4 CYL
FWD
AUTOMATIC
67,000 MILES
I bought this car 2 months ago and had no real problems until lest week. I drove it about 10 miles when it started knocking and died in about 30 seconds. I tried once to restart and it wouldn't start so I had it towed. What can cause this to happen it has Oil and the oil was changed 2 weeks ago there was a small leak noticed at the oil sending unit can that cause this?
(Merged)
MECHANIC
Hi there,
a small leak at the sender will not cause ethos un less the oil has all leaked out, I would be checking the oil pump and pressure relief valve, but if it has been run with out oil pressure to the point that it has started knocking and stopped I fear that it is all to late as serious damage has already occurred.'
mark (mhpautos)
SPONSORED LINKS
(Merged)
MOWENS1
MEMBER
Thank you for such a prompt reply. What could have caused this to happen? Could something have happened when they did the oil change?
(Merged)
MECHANIC
Hi there,
If they neglected to do up the drain plug tightly and it fell out and you lost all of your oil, this would account for it, otherwise I would be thinking of an oil pump or pressure relief valve failure.
Mark (mhpautos)
Saturday, October 10th, 2020 AT 9:38 AM
(Merged)
DYTBOI420
MEMBER
1 POST
1997 FORD ESCORT
1997 Ford Escort 4 cyl Front Wheel Drive Automatic
i need to know if this could be my oil pump. Theres oil that was blown all over the engine, the dip stick has way to much oil on it and its not from over filling it. Do you think that could be from my oil pump?
(Merged)
LEGITIMATE007
MECHANIC
Check your pcv valve and your air breather/air filter inside the airfilter box.
(Merged)
LEGITIMATE007
MECHANIC
You should also consider doing a oil change with a sludge remover before you refill it.
(Merged)
BLACKBOYWONDER
MEMBER
1 POST
1994 FORD ESCORT
6 CYL
FWD
AUTOMATIC
150,000 MILES
I want to no if my oil pump is about to go. My car started ticking in the engine like there is no oil in it but I just had a oil change and there is oil in car
(Merged)
BLUELIGHTNIN6
MECHANIC
Yep most likely if oil is in it but its acting as if its low on oil its the pump. Need to check oil pressure with a mechanical oil pressure gauge to see though.
SPONSORED LINKS
(Merged)
WESOLIV
MEMBER
1 POST
1993 FORD ESCORT
4 CYL
FWD
AUTOMATIC
182,000 MILES
I have an oil pump for a 1998 ford escort 2.0 liter sohc will the oil pump fit on a 1993 1.9 liter sohc engine
(Merged)
CJ MEDEVAC
MECHANIC
I made just "one" parts store search, below are my results
You might also verify what I found at another online auto parts store
product_Oil-Pump-Melling
