I am a mobile tech and computer crashed with my Aldata on it?
Saturday, September 6th, 2014 AT 3:41 PM
WRENCHTECH
MECHANIC
I assume this is a VIN 3 engine. I also assume you are referring to the cam bearing caps. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
SPONSORED LINKS
Sunday, September 7th, 2014 AT 5:48 AM
BIGGY25
MEMBER
1 POST
1994 FORD ESCORT
1994 Ford Escort 4 cyl
what is the tightening sequence and torque for the head on a 1994 escort engine?
Thursday, January 28th, 2021 AT 9:51 AM
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Hey BIGGY25,
Here is the cylinder head bolt tightening sequence and the foot pound and newton meter specs.
Cylinder Head Bolt (1) 56-60 (76-81)
Please let us know if you need anything else.
Best, Ken
Image (Click to make bigger)
(Merged)
STEVEN82
MEMBER
1993 FORD ESCORT
4 CYL
FWD
MANUAL
137,000 MILES
What are the spec for the torque on cylinder head
Thursday, January 28th, 2021 AT 9:52 AM
(Merged)
BLUELIGHTNIN6
MECHANIC
1.9L engines..
Tighten the cylinder head bolts in sequence (refer to the illustration) to 44 ft. lbs. (60 Nm).
1.8L engines..
Tighten the bolts in the proper sequence (refer to the accompanying illustration) in two or three steps to 56-60 ft. lbs. (76-81 Nm).
Thanks for using 2CarPros.com!
SPONSORED LINKS
(Merged)
STEVEN82
MEMBER
1993 FORD ESCORT
Engine Mechanical problem
1993 Ford Escort 4 cyl Front Wheel Drive Manual
