Firing order
WOLFGANG614
  • 1997 FORD CROWN VICTORIA
  • V8
  • 158,000 MILES
What is the order of the spark plug wires as to which cables go to which spark plugs? I was replacing the intake manifold, wires, and plugs and lost track of where the wires go.
Sunday, November 1st, 2009 AT 2:57 PM
WAY2OLD
  • 195 POSTS
https://www.2carpros.com/forum/automotive_pictures/382404_97_Crown_firing_2.jpg
Sunday, November 1st, 2009 AT 6:46 PM
MYDREW1952
  • 5 POSTS
  • 1989 FORD CROWN VICTORIA
  • V8
  • 155,000 MILES
Hello everyone, I am in need of help with my crown Vic. I recently had the engine gaskets replaced. The engine has been installed and sounds great. I just need the correct firing order/timing order for my vehicle. There is lots of hesitation when driving the car. I was told its due to the firing order from the distributor. I need the correct firing pattern. Thanks for all your assistance.
Thursday, December 5th, 2019 AT 12:14 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Here is the engine firing order below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
MYDREW1952
  • 5 POSTS
The previous order given in the diagram is not correct. Is there any other order that can be used.
MYDREW1952
  • 5 POSTS
Engine size is 5.0. It is a re-built engine. I don't know what else I can tell you about the it. Thanks for your help.
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_225.jpg
MYDREW1952
  • 5 POSTS
Engine Performance problem
1989 Ford Crown Victoria V8 Two Wheel Drive Automatic
i was previously sent the firing order for a 1989 Crown Victoria. It read as follows 1-3-7-2-6-5-4-8. G2247. I believe this is the incorrect firing order for my vehicle. Is there any information missing to obtain the correct firing order?
Is your engine a 351W if so its correct
MYDREW1952
  • 5 POSTS
Rasmataz: Thanks for your help. It is a re-built 5.0 engine. I not sure of any thing else.
A 5.0L is a CID302 engine F/O 1-5-4-2-6-3-7-8, the distributor rotates counterclockwise
Good Luck
