Engine coolant
2002 HONDA CRV
171,199 MILES
DJUNEMAN
Need to add coolant. Don't have antifreeze. Can I add straight water?
Dec 16, 2019 at 12:08 AM
DANNY L
  • CERTIFIED EXPERT
  • 5,648 POSTS
Hello, I'm Danny.
Technically if your in a pinch you can. However, diluting the mixture does have consequences.. How much do you need to add? Are you flushing the entire coolant system and need to add water only? The reason for the proper ratio of coolant/water is to lower the freezing point and raise the boiling point of the water in the vehicles engine and radiator. Hope this helps and thanks for using 2CarPros.
Dec 16, 2019 at 2:59 AM
