1999 Dodge Ram I WILL MAKE A GOOD DONATION IF YOUR RITE
BRYAN12345
  • 1999 DODGE RAM
  • V8
  • 97,000 MILES
WHENYOU PUT TRUCK IN DRIVE ITS NOT THERE UNTIL YOU GIVE IT GAS THEN IT GRABS AND TAKES OFF IT ALSO DOE THIS WHEN ITS WARM AND IF YOU COME TO A STOP
Monday, March 3rd, 2008 AT 8:13 PM
SERVICE WRITER
  • 9,123 POSTS
Start off by checking the BCM for any codes.
Fluid is full and clean I assume. Filter has been changed 2-3 times by now.I also Assume.
Monday, March 3rd, 2008 AT 8:48 PM
EPY
  • 19 POSTS
Im no mechanic but I would try a linkage adjustment somehow it may have gotten out of wack. Then try the filter and fluid, alot of mechanics and shops shy against this but you aint got nuttn to loose. Maybe one of your transmission lines are pinched shut from bumpy roads or rocks that flew up and hit them. Or the last deal is to visit your local U-Pull it junk yard and get another. There cheap there and you can practice before you put it on yours. Theres not a whole lot of options here but I told you what I would do. Happy hunting (post your prgress)
Tuesday, March 11th, 2008 AT 12:06 AM
JD0109
  • 7 POSTS
Iam no expert mechanic but in my day this ment the pump wasnt picking up the fluid. Change fluid and filter is a must. And make sure you change the fluid in the torgue converter. If this doesnt work your going to have to take it to the shop. If you take it to one of those quick oil change shopps make sure they change the filter and drain the torque converter.
Wednesday, April 9th, 2008 AT 8:56 AM
Related General Content
