THERMOSTAT
2003 DODGE INTREPID
GDEW
where is this location on my car so i can replace it
Mar 21, 2009 at 9:41 AM
  • 110,190 POSTS
Hi:
If you follow the upper radiator hose back to the engine, it will end at the thermostat housing. The t-stat is under the housing.
Apr 2, 2009 at 9:22 AM
W.FREEMAN78
3.5 engine where is thermostat located and how to replace?
Jan 5, 2020 at 1:25 PM (Merged)
WRENCHTECH
  • 20,761 POSTS
ENGINE COOLANT THERMOSTAT
REMOVAL
WARNING: DO NOT REMOVE PRESSURE CAP WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
1. Disconnect negative cable from remote jumper terminal.
2. Drain cooling system.
3. Raise vehicle on hoist.
4. Disconnect electrical connectors from engine oil and power steering pressure switches.
5. Disconnect radiator and heater hoses from thermostat housing.
6. Remove thermostat housing bolts.
7. Remove housing, thermostat, and gasket.
INSTALLATION
1. Clean gasket sealing surfaces.
2. Install thermostat and gasket into thermostat housing. For ease of installation, install bolts in housing for thermostat and gasket retention.
3. Install thermostat and housing to cylinder block. Tighten bolts to 12 Nm (105 in. lbs.) .
4. Connect heater and radiator hoses and install hose clamps.
5. Connect electrical connectors to engine oil and power steering pressure switches.
6. Lower vehicle and connect negative cable to remote jumper terminal.
7. Refill cooling system.
8. Connect negative cable to remote jumper terminal.
MSLCWILLIAMS
What is the location of the thermostat on the engine. Is there a site availabel to see a picture of it and how the area around it looks?
BMRFIXIT
  • 19,053 POSTS
I need an engine size
and I will try to get you a picture
most likely at the front of the engine if you follow upper hose to engine and thermostat housing
Jan 5, 2020 at 1:26 PM (Merged)
LESLIEWY
WHERE IS THE THERMOSTAT LOCATED ON MY 2001 INTREPID? AND HOW DO YOU GET TO IT?
2CARPRO JACK
  • 11,533 POSTS
Where the lower hose attaches to the engine.You need to lift and support the car, remove the skid pan and you will be able to see it. Great design huh? If you can find a shop to do it at a reasonable price, I would do it
LESLIEWY
[quote:a562d32ce3="2CarPro Jack"]Where the lower hose attaches to the engine.You need to lift and support the car, remove the skid pan and you will be able to see it. Great design huh? If you can find a shop to do it at a reasonable price, I would do it[/quote:a562d32ce3]
Thank You for the help.
KOKO2608
Where is the thermostat located in a 2001 dodge intrepid??? How do I get to it?
BMRFIXIT
  • 19,053 POSTS
V6
engine SIZE ????
In the middle front top of the engine
two bolts
make sure engine cool
drain down the coolant
remove the hose
remove the housing
make sure you bleed air out after you install the new thermostat
BMRFIXIT
  • 19,053 POSTS
OK
2.7L V6
drain coolant
remove alternator belt
raise the car
remove alternator and set aside
remove lower radiator and heater hose from thermostat housing
remove thermostat housing bolts
good luck
DANOXLEY40
Where is the thermostat located on the 2001 Intrepid? Is this something I can change myself easily?
  • 110,190 POSTS
Hi:
Follow the upper radiator hose back the the engine. It will end at the t-stat housing. The t-stat is in the housing and can be easily replaced by removing the housing. If you need help, let me know.
DANOXLEY40
Thank you for reply. I have found housing unit, how do i change thermostat. Do I remove hose, after loosenging 2 bolts? Any special instructions? Thanks.
  • 110,190 POSTS
Hi:
First drain the coolant from the radiator or you'll have a mess. Next, remove the housing and the t-stat will be under it. Before replacing the new one, pay special attention as to the direction the old one is sitting in. After removing everything, make sure to remove the old gasket from both the housing and the intake. Make sure the surfaces are clean and tight before replacing everything. Just reverse the sequence.
If you run into trouble or have other questions, let me know.
JOEYB5639
thermostat location 2000 intrepid 2.7L
There you go its located on the left side of the engine-see below
https://images.2carpros.com/forum/automotive_pictures/12900_thermostat_27_1.jpg
THEJERM
I have had a slight leak in my cooling system coming from whatever this picture is of. I thought it was the thermostat housing, I bought a new thermostat, went to unbolt this and tried loosening the bleed valve. Well, when applying torque to this bleed valve, the cover popped off. There is no fasteners, so, do I just "JB Weld" it back in place or do I need to buy a replacement (and if so... what is "it" called?) And, since this doesn't house the thermostat... where do I find it?
https://images.2carpros.com/forum/automotive_pictures/392196_0804092007_1.jpg
The thermostat is located on the lower drivers side of the block below the alternator. Its a pain to get at
THEJERM
rasmataz,
Thank you for directing me to the thermostat. Any chance you could tell me what it was that I broke (in the picture) or, if I can just use JB Weld (or some other form of epoxy) to stick that cover back on?
Thank you
DDHARRIS9
Need directions on replacing thermostat in 2001 Intrepid V-6 2.7liter
BMRFIXIT
  • 19,053 POSTS
[quote:6e3803d6b1="ddharris9"]Other Category problem
2001 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 96,000 miles
Need directions on replacing thermostat in 2001 Intrepid V-6 2.7liter[/quote:6e3803d6b1]
Drain coolant system
remove oil dipstick and tube .cover the opening so nothing can enter in the engine throw it
raise and support the car
support the engine and remove left motor mount
remove alternator
remove lower heater hose from thermostat housing
remove housing
you may have to remove tranny dipstick bracket bolt
good luck
COLDSTEEL9MM
  • 21 POSTS
Where is the location of the thermostat location on 1999 2.7L and how is it removed? Seen some web links that say its on the top of the motor in the middle and some others that say it's under the alternator.
SATURNTECH9
  • 30,869 POSTS
It says move aside the alternator to help.access the thermostat.
COLDSTEEL9MM
  • 21 POSTS
That means I have to remove the serpentine belt as well? I'm in a hotel parking lot.
COLDSTEEL9MM
  • 21 POSTS
Also, the temp gauge never went above half way but steam was coming from under the hood.
Thermostat or water pump?
LITTLEBIT1234
Engine Cooling problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
Here's a thermostat location for a 2.7L and 3.2L engine:
https://images.2carpros.com/forum/automotive_pictures/12900_27t_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_32t_1.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
WRENCHTECH
  • 20,761 POSTS
Sounds like you have a leak. The system needs to be pressure tested and I seriously doubt you are going to repair thing in any parking lot.
SATURNTECH9
  • 30,869 POSTS
I.agree with wrench tech sounds like.a.leak.was it the steam.coming from.the.cap.you might have a bad radiator cap.
WRENCHTECH
  • 20,761 POSTS
The thermostat on this one is a real bear. I don't see why he's changing anyway.
SATURNTECH9
  • 30,869 POSTS
I. know doesn't sound.like.it's even.overheating.
MVELEZ
I have a 1998 dodge intrepid ES 3.2 and I need to know where the thermostat is located. Could u help me out with a diagram or something...thanks
https://images.2carpros.com/forum/automotive_pictures/12900_t_4.jpg
The engine thermostat is located in a water box, formed in the front of the lower intake manifold. This thermostat has an air bleed located in the thermostat flange. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
MGW419
I want to chane the thermostat, and I am not sure of it's location. I think it's on the upper house leading into the engine. That fitting seems to have a nipple on it. Do you know what that is also?
Thanks!
BMRFIXIT
  • 19,053 POSTS
[quote:88fa22c64a="mgw419"]Heater problem
1997 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 109000 miles
Thanks![/quote:88fa22c64a]
Upper mid of engine
Follow upper radiator hose to engine and thermostat housing
make sure you bleed the system after thermostat replacement
good luck
DEMONHUNTER1200
M name is Ray and I just turned 16. For my bithday my parents gave me there old car. It has been running hot and I called around and found out i needed a thermostat. After buying one, no one on the block knows where it goes. I don't have the money to take it to a shop. My question is where does the thermostat go and does anyone know where I can find a diagram of the thermostat location that might help. Thank you.
Jan 5, 2020 at 1:27 PM (Merged)
VANDRAGON
  • 298 POSTS
it is located at the end of the top radiator hose at the top of the motor, where the hose is clamped to the housing. go to a parts store and ask if they have the time to come out to your car and show you where is goes and how to do it, other than that got to the store and look at a haynes manual. please don't try to repair this without the motor being cold.....good luck
