1996 Dodge Caravan msfire error codes
1996 DODGE CARAVAN
MASAI
I recently bought a used 1996 Dodge Caravan 3.0. It had an airbag light on, the horn did not work, and nor did the cruise control. I replaced the Clockscrew Assembly and everything is fine.
A few days later I got a Check engine light. It read p0300 and 0306, misfires. I replaced the Distributor cap and rotor and wires, spark plugs, Oil, filter and Air filter. The light went off, then reappeared the next day. The error code read spark plug six. I replaced that and the light went off. Then next day the error code appeared again, randon misfires and now it reads 4 and 6.
I replaced the fuel injectors and I'm still getting the misfire errors.
I'm stumped, what could it be?????-Masai
Jun 23, 2007 at 5:30 PM
BPRICE443
  • 66 POSTS
Check for vacum leaks in this area. Spay starting fluid around the intake manifold and if the motor changes the way it,s running there is a vacum leak.
Jun 26, 2007 at 1:03 AM
