Crankshaft sensor location
BIGGMIKE
  • 2003 NISSAN XTERRA
I have been looking for the crankshaft sensor, I cannot find it. Can you send me picture of where it is at? Thank you
Saturday, February 18th, 2012 AT 12:52 AM
DRCRANKNWRENCH
  • 3,380 POSTS
I did not know which engine or setup you have so I am attaching all three diagrams. One is for the four cylinder or 2.2L and the others are for the 3.3L one with and one without a supercharger.
Here is a guide that will show you what you are in for when doing the job and a diagrams below giving you the locations for your engine:
The location for all models is the same for the Crankshaft Position Sensor, CPS. It can be found at the top of the front of the transmission housing.
Cheers
Saturday, February 18th, 2012 AT 1:12 AM
BIGGMIKE
  • 58 POSTS
Thanks I found it.
Tuesday, February 21st, 2012 AT 6:23 PM
DRCRANKNWRENCH
  • 3,380 POSTS
You are welcome.
Come back anytime you need us and we will be here to help.
Dr C.
Wednesday, February 22nd, 2012 AT 12:40 AM
HEIDI WILSON
I am having an issue and I am not sure what to do at this point. I will try to be brief as possible. I have a 2003 Xterra supercharged 174,000 miles on it. A year ago the ignition switch went out in it so replaced that, then the alternator was bad put a new one in. Then in April of this year my timing belt broke. I took it to the shop and had that replaced and they checked for internal damage to the engine and thank God no problems. A few weeks later the SES light came on and I had it checked and was told the knock sensor was bad. It was running rough so that got replaced and still have the same rough running engine and loss of power along with the SES light still on. Any idea what could be causing this?
Monday, August 1st, 2016 AT 10:57 AM
CORYATENCIO
  • 2002 NISSAN XTERRA
  • 4 CYL
  • 174,700 MILES
Where is the crankshaft position sensor located?
Sunday, September 9th, 2018 AT 5:07 PM (Merged)
Crankshaft Position Sensor (OBD) (2.4L VIN D)At top rear of engine, on transmission housing.
Crankshaft Position Sensor (OBD) (3.3L VIN E)At top rear of engine, on transmission housing.
Crankshaft Position Sensor (OBD) (3.3L VIN M)At top rear of engine, on transmission housing
QUICKSILVER72
  • 2000 NISSAN XTERRA
  • 3.3L
  • 6 CYL
  • 129,000 MILES
I just wanted to know exactly where is the crankshaft sensor on vehicle? Need to change it out, But I do not know where it is exactly.
HMAC300
  • 48,601 POSTS
See picture. It is at back by transmission.
