Crankshaft position sensor
DUWHOP31
  • 2003 HYUNDAI SONATA
  • 2.4L
  • 4 CYL
  • FWD
  • 175,000 MILES
Im trying to locate where the crankshaft position sensor is on 2.4L & how to replace it?
Wednesday, March 11th, 2015 AT 9:21 AM
  • 108,199 POSTS
See attached pic for location.
To remove, locate the sensor on the engine. Remove the retaining bolt and slide the sensor from the engine. Disconnect the wiring and reverse the order to install.
Wednesday, March 11th, 2015 AT 10:58 AM
DUWHOP31
  • 151 POSTS
What size bolt
Wednesday, March 11th, 2015 AT 12:04 PM
DUWHOP31
  • 151 POSTS
& that's all I have to do? I dnt have take anything else off.
Wednesday, March 11th, 2015 AT 12:22 PM
  • 108,199 POSTS
I hate to say it, but I don't remember the exact size bolt. And yes, that should be it. However, I have to say there may be one issue. On SOME of these vehicles, the wiring for the sensor is behind the timing belt which makes it more difficult to access. It these cases, the belt may need removed to route the wiring properly and prevent damage to the wiring from the belt. If you determine your's is like that, I have to ask how much experience you have working on vehicles because removing the belt and replacing it requires a lot.
Wednesday, March 11th, 2015 AT 6:43 PM
DUWHOP31
  • 151 POSTS
Not too much & yeah I think its behind the belt
Wednesday, March 11th, 2015 AT 6:59 PM
  • 108,199 POSTS
I was afraid you would say that. In that case, the timing belt, tensioner pulley, and idler pulley need removed to safely route the wiring harness in order to prevent damage by the belt and pulleys. It's not an easy or fast job.
Wednesday, March 11th, 2015 AT 7:14 PM
DUWHOP31
  • 151 POSTS
Soo if I buy the crankshaft position sensor & dnt feel like I can instl it. Bout how much would an average shop charge me just to replace it?
Wednesday, March 11th, 2015 AT 8:47 PM
  • 108,199 POSTS
In estimate, I would think the average shop would charge you for around 3 hours labor.
Thursday, March 12th, 2015 AT 5:23 AM
MFIORE
  • 6 CYL
  • 49,000 MILES
Where is the crankshaft position sensor located on a 2004 sonata V-6 2.7
Monday, February 4th, 2019 AT 7:27 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
On top rear of engine under coil pack
JAREDSKI
  • 14 POSTS
  • 2002 HYUNDAI SONATA
  • 90,000 MILES
Where is it located on the 2.7l and whats the best way to go about getting it out
Monday, February 4th, 2019 AT 7:28 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
Its on rear of engine I posted how to change it couldnt find a diagram sorry.
SATURNTECH9
  • 30,870 POSTS
Sorry forgot to post the instructions.
JAREDSKI
  • 14 POSTS
Thanks i've been rackin my brain for awhile with this one heard to many different locations
SATURNTECH9
  • 30,870 POSTS
Your welcome thats what were here for glad I could help you out.
JAREDSKI
  • 14 POSTS
Boy that's not easy to get to (tiny hands) haha
MARCUS EDWARDS
  • 2000 HYUNDAI SONATA
  • 6 CYL
  • 150,000 MILES
Code 1154 shows on the computer - where is the crankshaft sensor located - I cannot find it. Thanks m.
DOCHAGERTY
  • 9,601 POSTS
Code 1154 is not a crank sensor fault. It is a lazy o2 sensor bank I that will require replacement.
SATURNTECH9
  • 30,870 POSTS
You have a import so they really pack things in there.
JAREDSKI
  • 14 POSTS
Ya and its not even my car I got a 69 camino and an 85 step side easy to work on
