Thermostat location and replacement?
YELLOWROSETTE
  • 2006 BUICK RANIER
  • 6 CYL
  • FWD
  • 101,000 MILES
I need to find the location of the thermostat
Sunday, May 17th, 2015 AT 8:29 PM
WRENCHTECH
  • 20,757 POSTS
It's on the side of the block. You have to remove the alternator to access it.
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/images/external/119095635.jpg.gif
Monday, May 18th, 2015 AT 2:09 AM
CORVETTETED
  • 2004 BUICK RANIER
  • 4.2L
  • 6 CYL
  • 4WD
  • 145,000 MILES
Check engine light code = P0128 was found indicating "low temp". I replaced the temperature sensor and thermostat (three different times) with aftermarket parts. Engine still will not come up to operating temperature of 192F. I am only getting a max temperature of 165F. Upon disassembling the original thermostat and comparing it to the aftermarket parts, I found that the original one seats on an o-ring and the aftermarket ones do not. Does that mean that the only thermostat that will work in this vehicle is an OEM part? Is that what I should try next or is there something else that could be causing my "low temp" error?
Monday, January 4th, 2021 AT 9:19 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Sounds like that is the case.. Those aftermarkets might be coming close but maybe there just running your car a little cooler. Putting in an OEM should take care of the problem. I have attached a tutorial for you but, I am sure you already know how to do it. Hope this helps and thanks for using 2CarPros.
Danny-
