Looking to remove cluster display and a diagram for removal.
Monday, December 2nd, 2024 AT 1:21 AM
KEN L
MASTER CERTIFIED MECHANIC
Here are the instructions on how to remove the instrument cluster, it looks like you will need to remove the trim panels from under the steering column and along the middle of the dash. Check out the images (below). Let us know if you need anything else.
Images (Click to make bigger)
Monday, December 2nd, 2024 AT 10:48 AM
COOKEE
MEMBER
2023 FORD ESCAPE
2WD
AUTOMATIC
4,500 MILES
I want to upgrade cluster display and would like to know how to remove the speedometer cluster display.
Thanks
Tuesday, January 14th, 2025 AT 11:44 AM
(Merged)
KEN L
Sure, here is how to remove the instrument cluster panel. Check out the images (below). Let us know if you need anything else.
(Merged)
COOKEE
MEMBER
2023 LINCOLN AVIATOR
6 CYL
4WD
AUTOMATIC
4,500 MILES
Looking the removal of the cluster display on a 2023 LINCOIN CORSAR I know I entered the Avatar but they are similar in display size & cockpit. But if you have the diagram for the CORSAR I glad appreciate it thank you.
(Merged)
KEN L
Here are your other questions did we miss something?
COOKEE
MEMBER
2023 LINCOLN NAVIGATOR
V8
4WD
AUTOMATIC
18,000 MILES
Need diagram to remove digital cluster display in 2023 ford navigator
Thanks
