I need to replace the wiper motor can you please help me?
Sunday, November 11th, 2012 AT 7:29 PM
MECHANIC
Here are the instruction in the diagrams below to show you how to replace the wiper motor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, November 11th, 2012 AT 8:23 PM
PAXDEANTHRO
MEMBER
1 POST
2000 CHRYSLER TOWN AND COUNTRY
2000 Chrysler Town and Country
I just replace the windshield wiper motor in my van and now the wipers are at rest in the up position. Based on other posts, it looks like I might need a different motor. Is this true, or is there another problem?
Wednesday, May 20th, 2020 AT 1:27 PM
(Merged)
MECHANIC
Hi:
The motor determines where the wipers park. If they are doing what you described, that is where the problem lies.
(Merged)
RHIANNACP
MEMBER
1 POST
1999 CHRYSLER TOWN AND COUNTRY
6 CYL
FWD
AUTOMATIC
132,000 MILES
I think my windshield wiper motor might be going out. Whenever I turn the wipers on they go up but get stuck going back down and I hear a loud whining noise. Not having any other issues with the vehicle besides this. Could it be the wiper motor?
(Merged)
MECHANIC
Will they come back down on their own eventually, or not? Also, you mentioned that you hear the motor running, have you checked the linkage to the wipers?
SPONSORED LINKS
(Merged)
ROBERT MCCARTHY
MEMBER
1 POST
1996 CHRYSLER TOWN AND COUNTRY
6 CYL
FWD
AUTOMATIC
235,000 MILES
No power going to wiper motor checked fuse and relays check out good changed motor still does not work
(Merged)
MERLIN2021
MECHANIC
FRONT WIPER/WASHER SWITCH NOTE: Wiper/washer switch is part of multifunction steering column switch. If wiper/washer switch fails, entire multifunction switch must be replaced. Disconnect wiper/washer switch connector. Using ohmmeter, test for continuity between switch terminals with switch position as indicated. See WIPER/WASHER SWITCH CONTINUITY TEST table. See Fig. 2 . If continuity is not as specified, replace multifunction switch.
(Merged)
CARADIODOC
MECHANIC
Very common problem is a defective body computer. Not sure why they had to computerize a wiper system, but it's one of the reasons people don't want to buy new cars. I've known a few people who just ran a wire from a toggle switch on the dash board to the wiper motor and forgot about the delay function. Cheap "fix" for an expensive, unreliable computer.
