Windshield wipers do not work
TOMDAWG
  • 1990 CHRYSLER LE BARON
Six cylinder front wheel drive automatic 72,000 miles
Hel ! My windshield wipers do not come on at all. I have changed the fuses, the switch and the wiper motor, but still nothing. They do not even attempt to come on. Could the new motor be bad, since I did get is used? Or is it something else?
Wednesday, September 30th, 2009 AT 12:32 PM
CH112063
  • 1,320 POSTS
Changed the fuse, motor switch? If it is a new motor a separate ground from the wiper motor housing to any secure ground to the frame will tell you the story. That was a weekly fix. Bad wiper motor ground.
Monday, October 5th, 2009 AT 10:55 AM
TOMDAWG
I went ahead and ran a wire from the cover screw to the block and that did the trick. I was under the assumption that the motor was case grounded, but I guess this happens when the car gets old. I put the old motor and switch back on too. Saved a few bucks. Thanks alot for your help.
Monday, October 5th, 2009 AT 2:56 PM
CH112063
  • 1,320 POSTS
It is I who thank you. It is nice to see, understand, and fix. Down the road.
Mr. Tomdawg. Anytime, Joe
Monday, October 5th, 2009 AT 6:11 PM
JIMMY WHEELER
  • 1991 CHRYSLER LE BARON
  • 6 CYL
  • 190,000 MILES
Six cylinder two wheel drive automatic 190,000 miles
My windshield wipers just stopped working while in use. I can hear the motor to the wipers running they seem fine. Why will it not move the wipers back and forth. What can I do to fix this? I am stuck and I cannot afford to take it to a shop. Please tell me somethings I can try.
Friday, December 30th, 2016 AT 2:01 PM (Merged)
CARADIODOC
  • 33,754 POSTS
The linkage probably popped off the motor's arm. Line the ball and socket up, then squeeze them together with a pliers. If it pops off again, the nylon socket is worn out and the linkage must be replaced. Good used ones should be fairly easy to find in most salvage yards.
Caradiodoc
  • 0 POST
  • 1988 CHRYSLER LE BARON
  • 89,328 MILES
My wipers do not work. I have replaced the wiper motor and fuses twice and checked the current coming through the plug to the wiper motor and its putting out 12.4 volts when switch is turned on. I hear a click noise when I turn wiper switch on under dash. Any ideas why my wipers do not work? Also went to dealership and they said there is no relay for this car.
CARADIODOC
  • 33,754 POSTS
Were the fuses blown? Ground a test light to the battery negative post or engine block, then test for voltage on the case of the wiper motor. If you have voltage there, attach a new ground wire between the motor and the body.
KSUKEV777
  • 1992 CHRYSLER
It has just snowed and now my windshield wipers will not work. The blades are fine and free of ice. I also have a problem with the car battery draining if not driven after two days or so. What may be the problems?
Friday, December 30th, 2016 AT 2:49 PM (Merged)
CARUNDELL
  • 602 POSTS
Hey ksukev, as to the wiper issue, you may have simply blown the fuse for the wiper motor I would start there first. As to the battery drain, first check to make sure all interior lights a switched off, including the glove compartment and trunk lights, then unless you have a good DVOM and are familiar with "parasitic draw" testing I do not recommend it, but if you do then I would be happy to walk you through it!
Regards,
Chris
