1997 Chevy Monte Carlo stopped running
1997 CHEVROLET MONTE CARLO
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
HONDAR
the car had started jerking and shaking went to pull off the side of the road, then it died. wouldnt start. had it towed home. and when you go to start it, it will start but will only stay running for about 2-3 seconds. brother said it probably the timing belt. some one else said that if it starts then it isnt the timing. what is your suggestion.
Jan 23, 2008 at 4:12 PM
  • CERTIFIED EXPERT
Start with this-feed the throttle body constantly with carb cleaner does it coninue to run ?
Jan 23, 2008 at 4:20 PM
