2001 Chevy Impala Trunk opens automatically
TIMINATOR67
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 78,500 MILES
My trunks keeps opening by itself; also I just ordered a new fob & I cant program it
Do you
have the same problem?
Friday, October 10th, 2008 AT 10:12 AM
MERLIN2021
  • EXPERT
Sounds like the trapalert system, here's the tech bulliten on the system.
http://www.2carpros.com/forum/automotive_pictures/62217_trapalerctb_1.jpg
REMOTE KEYLESS ENTRY SYSTEMS -2001 Chevrolet Impala
Page 1 of 1
NOTE: All RKE transmitters recognized by RCDLR must be programmed during programming sequence. If system is placed in program mode, it will erase all previously programmed RKE transmitters upon receipt of programming signal from first transmitter.
NOTE: Scan tool must stay connected until all of transmitters are programmed.
RKE TRANSMITTER PROGRAMMING
1.Install a scan tool. Turn ignition switch to RUN position. Using scan tool, access Body Control Module (BCM) SPECIAL FUNCTION in PROGRAM KEY FOBS menu. 2.Press and hold LOCK button and UNLOCK button simultaneously on one transmitter. After 15 seconds, BCM will chime in order to confirm programming of that transmitter. 3.Repeat previous step in order to program up to 4 transmitters. Remove scan tool. Operate transmitter functions in order to verify correct system operation. 4.Remove scan tool. Operate transmitter functions in order to verify correct system operation.
10/10/2008
Friday, October 10th, 2008 AT 4:05 PM
Recommended Guides
