2001 Chevy Impala ECU
GOLDY
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 165,000 MILES
Where is the ECU on a 2001 chevy impala 3.8 L and how do you replace it?
Do you
have the same problem?
Friday, April 17th, 2009 AT 4:39 PM
The PCM is in the aircleaner box
Friday, April 17th, 2009 AT 5:44 PM
GOLDY
Excuse my ignorance; but is the PCM and ECU the same thing and is it difficult to replace?
Thanks
Friday, April 17th, 2009 AT 7:03 PM
Its the same thing-disconnect the negative battery cable then find it and unplug the wiring connectors-Bear in mind that you might have to go thru a computer relearning process after replacement due to battery disconnection.
Friday, April 17th, 2009 AT 8:32 PM
Recommended Guides
