My 4 speed linkage kept getting hung up when I'd shift. When I checked the linkage, sure enough, several of the nuts that hold the 3 linkage arms to the trans. Were loose. When I tried tightening the nut on the reverse gear the bolt sheared off about 1/2 inch. I can now just barely get a nut on the bolt with no room for the lock washer.
Question: Can I remove that bolt (stud) and replace it w/o removing the trans? There's very little room. What would you suggest?
Tuesday, January 29th, 2008 AT 8:34 AM
