1999 Chevy Cavalier INSTALLING AFTERMARKET BULLDOG REMOTE D
JPISKAC
  • 1999 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 168,000 MILES
TRYING TO FIND WIRING DIAGRAM THAT SHOWS CORRECT WIRE MATCHING FROM FACTORY TO BULLDOG REMOTE START SYSTEM MODEL RS1200
Wednesday, April 28th, 2010 AT 11:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remote start systems uses several wires, would need to know which systems you need wire diagram for so I can post each one.
Thursday, April 29th, 2010 AT 12:30 AM
JPISKAC
THE DIAGRAMS I NEED ARE FOR DOOR LOCKS AND TRUNK RELEASE, THE MODULE HAS 5 WIRES FOR THE DOOR LOCKS ONE IS ACCORDING TO BULLDOG A NEGITIVE OR POSITIVE, BUT WHY 5 WIRES WHEN THE LOCK CIRCUIT ONLY HAS 3 WIRE THANK YOU
Thursday, April 29th, 2010 AT 10:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Do you have keyless entry? that may be the reason for the wires you talk about..below is the wiring diagram , the doorlocks WITH keyless entry includes the trunk release.
if its too small then post your email addy so i can email to you, then you can enlarge it in email..
http://www.2carpros.com/forum/automotive_pictures/261618_Noname_2070.jpg
http://www.2carpros.com/forum/automotive_pictures/261618_Noname2_667.jpg
Thursday, April 29th, 2010 AT 2:07 PM
JPISKAC
THANK YOU VERY MUCH THIS WILL HELP GREATLY.
Thursday, April 29th, 2010 AT 5:44 PM
JPISKAC
JPISKAC@HOTMAIL. COM
Thursday, April 29th, 2010 AT 5:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Diagram sent, let me know how it goes
Thursday, April 29th, 2010 AT 8:11 PM
JPISKAC
THANK YOU I KNEW I WAS RIGHT ON WHICH WIRE WENT WHERE, AND THE DIAGRAM PROVED IT, I FOUND OUT THAT THE DIP SWITCH FOR THE TRUNK RELEASE NEEDED TO BE FORCED INTO THE POSITIVE POSTION. IT DID NOT STAY THE FIRST TIME I HAD PUT IT IN POSITION. IT'S PRETTY BAD WHEN AN ASE CERT TECH HAS ISSUES WITH SOMETHING SO SIMPLE DUE TO A MANUFACTURER PROBLEM. LOL THANK YOU VERY MUCH FOR THE HELP
Sunday, May 2nd, 2010 AT 6:13 PM
Related General Content
