Plugs are all a nice tan color as should be & pulled each wire one at a time while running to check for cylinder misfire.
result engine ran worse with each wire removed, so all cylinders are firing.
Did a fuel pressure test:
result was 36psi with no leak done.
Did a compression test:
#1 90psi
#2 95psi
#3 90psi
#4 90psi
Friday, October 22nd, 2010 AT 4:25 AM
