Why is my right parking light not working
RAM66
  • 2000 BUICK LESABRE
  • 18,000 MILES
The right blinker light (same bulb) works fine. I tried replacing the bulb 3157 but it did not correct the problem. The same problem is still occuring.
Monday, September 5th, 2011 AT 9:10 PM
  • 31,938 POSTS
May be a bad connection in the globe holder, check that you have power and earth use a multi meter to check this.
Monday, September 5th, 2011 AT 10:52 PM
ROBERT REMELIUS
  • 1997 BUICK LESABRE
My 1997 Buick lesabre's headlights, turn signals and brake lights all work but my tail lights do not, I checked the fuse and the bulb.
Tuesday, July 9th, 2019 AT 2:27 PM (Merged)
  • 108,179 POSTS
Check the headlight switch to make sure it is sending power to them. If it is, start at the tail lights and trace the wiring back to the switch to see where power is lost. It sounds like the lamp control module is out here is the location. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
TURBOJAY
I had this problem had to get a new LCM cost me $143.00 all fixed! I love this site.
STEPHEN DEZELLE
  • 2001 BUICK LESABRE
  • 3.8L
  • 6 CYL
  • FWD
  • 140,000 MILES
Why my tail lights do not work, but my brake and signals do?
HMAC300
  • 48,601 POSTS
I am assuming that you have checked the bulbs and fuse for this. See picture the fuses and relay are under the rear seat fuse box. It can also be a module so if all is good then you need a mechanic to scan to see if it is a module problem.
JASONFLOHR
Electrical problem
2000 Buick Lesabre 6 cyl Front Wheel Drive Automatic
I just replaced the bulbs in my passenger side tail lights. The brake and blinker now works but the two bulbs in the running lights dont work. I suspct wiring or is there and inline fuse? Is this some thing a can plug a new harness in and be good or will I need to splice?
Wednesday, July 10th, 2019 AT 9:54 AM (Merged)
KLSHIEL
  • 163 POSTS
The rear running lights for both sides are on the same fuse. I would pull the whole tail light out and check the grounds. You will need to splice in order to change a socket, but it is not too hard if you do one wire at a time with the new socket. I would also try turning the bulbs around 180 as this occasionally works.
