2001 Buick Century thermostat
KAZ285
  • 2001 BUICK CENTURY
Engine Cooling problem
2001 Buick Century 6 cyl Automatic
I need to know how to exactly remove and replace a thermostat. I look at the other questions and could not find out how. I know where the housing is at but there is allot of other things it look like I need to take off first. I'm not sure if I can just start removing things with out consequences so I thought I just ask first.
Thanks in advance.
Friday, June 27th, 2008 AT 5:17 PM
MASTERTECHTIM
  • 4,750 POSTS
What size engine? The eighth letter of the vin?
Friday, June 27th, 2008 AT 5:44 PM
KAZ285
Its the J-model.
Saturday, June 28th, 2008 AT 3:35 AM
BMRFIXIT
  • 19,053 POSTS
Drain some coolant
carefully remove the throttle body air inlet duct
remove the air pipe
remove the exhaust crossover pipe
loosen and reposition hose clamp at the housing
disconnect the radiator hose from housing
remove the thermostat housing bolts and remove thermostat and gasket
Risk of fire.
Keep cigarettes, sparks, open flame, and other
sources of ignition away from vehicle.
Gasoline, methanol, and oxygenated fuels are toxic
and flammable and must be handled appropriately
Saturday, June 28th, 2008 AT 5:39 AM
Related General Content
