Blue smoke
MICHAEL W ADAMS
  • 2004 FORD F-350
  • 6.0L
  • V8
  • TURBO
  • 4WD
  • 255,000 MILES
This morning my truck was fine and running perfect. I shut it off for about an hour and when I left again I felt a miss and it started smoking when accelerating. When I reach speed its minimal smoke. But at slowest speeds and take off is when it happens. But this morning it ran perfect. I changed the oil put injected cleaner in it and changed the fuel filter. It's a powered role 6.0 diesel.
Do you
have the same problem?
Tuesday, December 31st, 2019 AT 2:24 PM
  • EXPERT
Good evening,
the first thing I would check is the turbo. Remove the inlet hose and look for signs of oil. You may have a failing turbo.
Tuesday, December 31st, 2019 AT 3:40 PM
