We are trying to figure out why the blinker on the right side front will not blink, we have replaced the bulb. But the back blinks and it will not blink steady inside, like the left does. All blink, except the one. We still have to replace the back top brake light and dome light. Not sure how to replace the dome light. Also, the radio will not work and it just makes a beeping/morse code like noise and will not play. We checked the fuse box, the only one we could find. The fuses looked fine. Not sure how to fix the blinker problem and the radio. We just got this today. Also the car shakes when you hit around 40-55 and vibrates. Not sure, if there was a little clicking noise and felt like I was in drive 1 or something, ran kind of like a low gear. What is that all about? The motor did shake. But, since we boot new boots and sparks plugs, oil change. We do not understand why this does this? When we got home, we say transmission fluid leaking and it was a broken hose that was very hard to get to. We will get the part monday, when it comes in. One more thing, the ABS light is on, what should I check? We will be putting new front brake pads on tomorrow. What else could it be? It is a 4 quard, 4 cyl.
Thanks so much.
Jaime
Thanks so much.
Jaime
Apr 28, 2007 at 10:03 PM
