Air Filter Replacement
AFMII
  • 2007 ACURA TL
  • 6 CYL
  • FWD
  • 26,000 MILES
How do I replace my engine air filter?
Friday, October 29th, 2010 AT 9:11 PM
SERVICE WRITER
  • 9,123 POSTS
Buy the filter.
Remove the screw highlighted in the front and find the back ones. Lift off cover and remove the old filter, reverse procedure to install.
https://www.2carpros.com/forum/automotive_pictures/30961_air_3.jpg
Saturday, October 30th, 2010 AT 8:37 AM
FORTE
  • 2004 ACURA TL
  • 6 CYL
  • FWD
  • 126,000 MILES
How do I access and replace the engine compartment air filter on my 2004 TL?
Wednesday, January 27th, 2021 AT 2:09 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2004_acura_TL_air_filter_1.jpg
Air Cleaner Element Replacement
NOTE: Do not use compressed air to clean the air cleaner element.
1. Open the air cleaner housing cover (A) and remove the clamps (B).
2. Remove the air cleaner (C) from the air cleaner housing (D).
3. Install the parts in the reverse order of removal.
There you go.
BTULSHI
  • 2004 ACURA TL
  • 6 CYL
  • FWD
  • 80,000 MILES
How to replace the engine air filter?
KHLOW2008
  • 41,815 POSTS
Hi btulshi,
Here are the procedures.
AIR CLEANER REMOVAL/INSTALLATION
1.Remove the bolts (A) and clamps (B).
https://www.2carpros.com/forum/automotive_pictures/192750_AirCleaner04TLFig37_1.jpg
2.Remove the air cleaner (C).
3.Install the parts in the reverse order of removal.
ERIC JUSTIN STEVENSON
  • 2002 ACURA TL
  • 3.2L
  • V6
  • 187,000 MILES
Does the type s take the same air filter as the base?
Wednesday, January 27th, 2021 AT 2:10 PM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny
No, The TL base model and the Type S air filters are different. I've attached the pictures below with the part numbers from AutoZone parts stores. The Fram CA8475 is for a TL base model and Fram CA9502 is for a Type S. Hope this helps and thanks for using 2CarPros.
DANNY L
  • 5,648 POSTS
Hello again.
Here is a tutorial showing how to replace an air filter.
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
I've attached a few picture steps below showing how to replace the air filter on your Acura. Hope this helps and thanks again for using 2Carpros.
Danny-
