car will not start checked everything
1997 ACURA INTEGRA
219,000 MILES
JONATHANMELISSAPOWELLFORBES
  • 6 POSTS
Has spark and gas. put on computer no codes. everything seems to work, but nothing. car ran fine turn it off and got in it about thirty minutes later started car did a half a turn and car shut off.
Sep 9, 2012 at 4:38 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Check the fuel pressure. If you do not have any fuel pressure, check the fuel pump operations. The PGM-FI main relay is known to fail causing intermittent non-starting.
Sep 9, 2012 at 4:43 PM
  • 6 POSTS
okay, i have fuel so would it still be the main relay?
Sep 9, 2012 at 5:24 PM
  • 6 POSTS
it has good spark when i turn the key fuel shoots out the fuel rail. Has compression no codes, new spark plugs, will not start on ether.
Sep 9, 2012 at 5:26 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Sparks, compression and fuel pressure. Try some starting fluid. If it fails to start, check the timing belt for skipped tooth.
Sep 9, 2012 at 6:53 PM
CJ MEDEVAC
  • CERTIFIED EXPERT
  • 11,004 POSTS
" Thirty minutes later started car did a half a turn and car shut off"
"half turn" sounds like the battery, connection, or starter problems.
Later portion of this deals with connections.
Http://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
Battery can be tested in or out of your rig at a popular auto parts store, you can get it running and over there (with a jump or a "charged battery". this same machine can test your entire charging system to insure your battery is being charged by the alternator if it is not, you will soon be back in the same situation.
Keep us posted
The Medic
Sep 9, 2012 at 7:42 PM
  • 6 POSTS
sorry about that when i said half a turn i got in it and it started so i put it in gear and drove it went to do a u turn and in the middle of the turn it just shut off no noise or anything. i have spark, i have fuel in it. I tried starting fluid, but it still will not start. checked the relay it is working.
Sep 9, 2012 at 8:17 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
You mentioned compression, was it tested?
Sep 9, 2012 at 8:20 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
By the way, are the sparks bright blue or dull orange?
  • 6 POSTS
yeah, got compression and the spark plug are new but in the old plugs the where orange i will check real quick with the new ones and see.
Sep 9, 2012 at 8:35 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
If everything lines up good and the sparks are orane, you have a weak ignition coil that is not providing sparks strong enough to start the engine. A weak ignition coil would also fail when it is hot.
Sep 9, 2012 at 9:36 PM
  • 6 POSTS
checked the spark that is blue and put a new rotor button in among testing it i sat the plug on top of engine over the hole it came out of and tried to start it and it shot out flame.
Sep 9, 2012 at 11:55 PM
KHLOW2008
  • CERTIFIED EXPERT
  • 41,814 POSTS
Looks like you have an over fueling situation. Maybe the injectors are opening too much and that can be due to a problem with the engine coolant temperature sensor.
Remove all spark plugs and disconnect the PGM-FI main relay. Crank the engine for a few seconds to clear out the cylinders of excessive fuel. Reinstall everything and try starting.
Sep 10, 2012 at 12:04 AM
