If you want to get back to the basics of making sure you have everything correct follow these instructions.
A few ways to do this. With both ways, make a point to watch which direction the bottom "crankshaft pulley" is rotating when the starter in engaged.
1) Install compression tester in Cyl #1 (usually the one closest the pulley on 4cyl engines) and have someone tap the key until you see the pressure starting to come up. This will put you on the compression stroke of #1 cyl. Put a socket on the crankshaft bolt and continue rotating the engine (in the same rotation you witnessed earlier) until the TDC mark "0" lines up with the timing pointer on the block.
Then pop open the distributor cap. You should be pointing toward plug wire #1. If not, pull all the plug wires out of the cap and install plug wire #1 right where the distributor is pointing to. Then follow losone’s information on the rest of the firing order based upon the rotation of the rotor inside the dist. Cap.
2nd way to do it (if you don't have a compression tester)
Pop off the valve cover and put a socket on the crankshaft bolt and continue rotating the engine (in the normal rotation) until you see the intake valve(s) open and close (easy way to tell the difference between intake and exhaust valves is to see which side is connected to the muffler and which side is connected to the intake, wahh laa exhaust side=exhaust valve / intake side = intake valve - it's really easy to tell)
Now once you see the intake valve open and close keep turning the crank pulley until the TDC mark "0" lines up with the timing pointer on the block. You should now be on "top dead Center" on the compression stroke.
Hope this helps
Tuesday, April 4th, 2006 AT 10:45 PM
