Beetle won't shut off with ignition switch
1974 VOLKSWAGEN BEETLE
100,000 MILES
KATIE112
Recently bought a 1974 Beetle that will not shut off with the ignition switch. Have replaced the ignition switch. It shut off with the switch a dozen times but now will not. What should I check?
Jan 22, 2012 at 3:15 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
make sure the power to the coil i s being cut off for one. check all grounds make sure they are good as well, batt to body, to eng, etc.
Jan 22, 2012 at 6:37 PM
T-BONE81
How do you change the ignition switch, I do not have the key
Jan 5, 2020 at 6:48 PM (Merged)
MIKE H R
  • 3,094 POSTS
you do need the key, you have to put the key in the slot and then with a pin or straight piece of wire push it in the little hole, then turn the key counter clock wise.
COGNITO
  • 28 POSTS
remove 6mm allen bolt securing switch,signal,wiper housing. Remove wipe/signal switch.Keep tension off steering lock[wiggle steering wheel].Its tight, but pry back steering lock pin from colmn,Pull on housing[you may have to persuade with a soft hammer ]You will see a phillips screw securing the ignition switch in place.The ignition tumbler has a clip that needs to be depressed after drilling through the housing to remove.Look at the new tumbler to figure drilling dimentions
ENDICOTTB
Other Category problem
1973 Volkswagen Beetle Two Wheel Drive Manual 140000 miles
How do you change the ignition switch in a 73 volkswagen beetle
Jan 5, 2020 at 6:49 PM (Merged)
MIKEYDEP
  • 29 POSTS
if i remember correctly,,, there's a little pin inside the
switch....you have to put the key in and turn it to the "on" position...
the unit should just come out...
after the preliminaries of course
you do mean the switch on the steering column right?
COGNITO
  • 28 POSTS
If the ignition housing is removed then their is a clip that needs to be depressed te
