Well that's a lot of spaghetti work. I will make a video once I put it back together.
Tuesday, June 25th, 2019 AT 12:01 PM
MECHANIC
I agree with Ken. There is a short to power in that purple wire going to the starter. Did anything look out of the ordinary when you removed the fuse/relay box? I realize there are a lot of wires there. Only focus on the ones that go to the starter relay.
Let us know.
SPONSORED LINKS
Tuesday, June 25th, 2019 AT 6:11 PM
JEFF KAARTUNEN
MEMBER
Nothing looks out of place in the relay box.
Wednesday, June 26th, 2019 AT 10:40 AM
KEN L
MASTER CERTIFIED MECHANIC
I would run a new wire then it must have a short a power somewhere.
Wednesday, June 26th, 2019 AT 11:24 AM
JEFF KAARTUNEN
MEMBER
So run a new wire from relay to starter? Also, this is a automatic and not a manual if that makes makes a difference.
SPONSORED LINKS
Wednesday, June 26th, 2019 AT 11:49 AM
MECHANIC
Welcome back:
Ken, what are your thoughts about having power to 3 of the 4 pins where the relay plugs in. There should only be power to 1 all the time, correct?
Wednesday, June 26th, 2019 AT 6:23 PM
JEFF KAARTUNEN
MEMBER
Saturday, June 29th, 2019 AT 7:10 AM
KEN L
It sounds like you have major wiring harness problem do you have an damage on the harness? Did you get a chance to make us a video so we can see what is going on? That would help us fix it.
Saturday, June 29th, 2019 AT 5:06 PM
JEFF KAARTUNEN
MEMBER
Been busy with other things past few days. Try to get it going for ya soon. Arms been in a lot of pain since surgery.
Sunday, June 30th, 2019 AT 12:54 PM
MECHANIC
Welcome back, Jeff. I'm sorry to hear about the surgery. I hope all is well. Listen, we are here to help you. When you have the chance, it will be fine with us.
