Change the serpentine belts
ANN NAGLE
  • 2004 TOYOTA RAV4
We have 87.000kms on the clock and we've been 'advised' to change the serpentine belts, water pump etc before taking a 2.000 km trip. Will be using motorway mostly. What to do? Normally Rav 4 doesn't need this kind of work till about 105.000KMS. We don't have money to burn getting maintenance when none is needed. Car is regularly maintained and well looked after. 2 careful drivers.
Wednesday, September 16th, 2009 AT 9:27 AM
  • 108,170 POSTS
Here is a guide to help walk you through the replacement with diagrams below to show you how on your car.
https://www.2carpros.com/diagrams/toyota/rav4/2004
and
https://www.2carpros.com/articles/replace-serpentine-belt
Monday, November 23rd, 2009 AT 4:16 PM
SLHIATT
  • 2003 TOYOTA RAV4
  • 4 CYL
  • FWD
  • 42,000 MILES
How do I change the serpentine belt in my Rav4?
Thank You,
Scott
Tuesday, September 10th, 2019 AT 5:53 PM (Merged)
PIFF
It is worth it to have this done by a mechanic. Instant oil change facilities do this with proper tools and quickly for less money. Can be very tricky to do in Japanese cars because of tight placement of the belt.
SHIZMI712
  • 2001 TOYOTA RAV4
Engine Mechanical problem
2001 Toyota Rav4 V12 All Wheel Drive Automatic
procedure for replacing serpentine belt on 2001 rav4
BLUELIGHTNIN6
  • 16,542 POSTS
Using a breaker bar and appropriate sized socket (or appropriate drive belt removal tool), relieve the belt tension by rotating the tensioner. Do this slowly over about 3 seconds.
Remove the belt from the pulleys.
Installation is the reverse of removal. Be sure to follow the belt routing diagram.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_185.jpg
Thanks for using 2CarPros.com!
