No power in acceleration
FARID.786
  • 2004 TOYOTA PREVIA
  • 87,000 MILES
Hi I have 2004 Toyota previa 2.0d4d t2. It seem there is no power in acceleration especially on uphill as it only does 25mph in second gear and when you change to third it only does 30 mph and start to drop speed.
Car looses power especially on uphill it only does 25 mph in second gear and when you change to third it goes to 30 mph with struggle.
Sunday, February 5th, 2012 AT 3:54 PM
FIXITMR
  • 9,990 POSTS
No CEL? is MAF sensor dirty? Possible/likely turbo boost issue. Here is a guide that will help
https://www.2carpros.com/articles/engine-has-low-power-output
Sunday, February 5th, 2012 AT 4:43 PM
SU
  • 1997 TOYOTA PREVIA
  • 89,000 MILES
1997 toyota previa automatic, power loss after driving for 30 minutes on the motorway speed drops from 60mph to 30mph despite accelerating. Thought it was transmission slipping but oil changed and appears to change smoothly, engine does not overheat and no engine lights on dash can anyone help?
Friday, December 13th, 2019 AT 12:47 PM (Merged)
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it and keep testing.
WHEELIEZ
  • 6 POSTS
  • 1993 TOYOTA PREVIA
Electrical problem
1993 Toyota Previa 4 cyl Two Wheel Drive Automatic
I am just wondering how to remove the distributor and properly replace it. I suspect that is my problem.
For some time now my toyota previa will not rev beyond 2400 RPM, no matter how hard you accelerate. Also when it rains, or I run through a puddle, the vehicle quits.
I am also wondering how to access the spark plugs and wires as they are under the van. It is a Mid-engine setup.
I am greatful for any assistance you can provide
The throttle position sensor wire harness is known to be a trouble maker-that can be causing your problem.
To get to the distributor you need to remove the skid plate below it.
For the sparkplugs its under the passenger seat, you have to remove the seat and cover below it to expose them
WHEELIEZ
  • 6 POSTS
I don't believe that it would be my TPS wiring harness as I got the replacement harness kit, and replaced a suspected bad TPS at the same time, which leads me to my distributor.
When you replaced the TPS did you check the closed and WOT voltages? Also tested the MAF sensor-
WHEELIEZ
  • 6 POSTS
Closed throttle 0 volts
WOT 10 volts.
Airflow meter was recently replaced for the one time low low price of $1427.43
WHEELIEZ
  • 6 POSTS
Ok finally got the plugs and wires changed and I cannot access the distributor cap from under the passenger seat. Is it better to go from under the vehicle? One more note, I had indicated that it would not rev beyone 2400 RPM, that is only when in gear. When it's in neutral or park, it will rev to red-line. Now, if I shift manually, it goes like a bat out of hell, but when it shifts on its own, it won't rev and there is no kick-down. Any thoughts? I have already been to the dealership and sought their advice. They inspected the cable and adjusted it to factory specifications. I am gettin frustrated with this vehicle. HELP! PLEASE!
ALVAREZ7
  • 1992 TOYOTA PREVIA
When starting it struggles to push forward
  • 108,179 POSTS
Does the problem seem to be related to the engine or the transmission? Has the check engine light come on? Have you checked the fuel pressure to the engine?
ALVAREZ7
We just got the engine changed, the check engine light hasnt turned on, and where can I check the fuel pressure?
  • 108,179 POSTS
For direction on checking fuel pump pressure, go to our homepage under the DIY section for directions and a video.
