2CarPros - Car Questions & Answers
2003 Toyota Highlander Repair Question
Topics covered: Axle, Axle nut, Brakes.
Asked on March 22, 2008
2003 Toyota Highlander removing front rotors
I'm attempting to replace a front rotor on my 2003 Toyota Highlander. 4 cyl, 2wd. There is a front axle nut that I cannot remove even with 125 psi on my impact wrench. Is this nut actually thredded or a nylon pressed on nut?I also see two thredded holes on the front face of the rotor, What size are these(Metric) ? and if thredded with bolts will they press the rotor off the axle with this nut in place?
Avatar Asked by ltralph13
Answer
Replied on March 22, 2008
yes leave the nut alone. the bolts are 8mm by 1.25 just screw them in evenly, spray with penetrating oil and tap with a hammer. they should come off fairly easy. hit it hard with the hammer if you have to, it will pop off. hope this helps
Tiny Answered by mastertechtim
7 questions asked
