1989 Toyota Cressida
Engine Mechanical problem
1989 Toyota Cressida 6 cyl Two Wheel Drive Automatic 170000 miles
I was driving my car and all of a sudden it just cut off
and now it won't start. Any idea's?
May 14, 2010.
Hi perezrx, Welcome to 2carpros and TY for the donation
Let's do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 15, 2010.
