Heat/AC blower motor not working
2005 TOYOTA COROLLA
FNEE
The heat/AC blower fan has been shutting off intermittently and now does not come on at all on any setting. Is there a relay that controls this fan? Both the heat and A/C function properly, it is just the blower that does not work.
Mar 8, 2010 at 6:24 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
This sounds like the blower motor has gone bad. Here is a guide to help you confirm the issue and the location of the blower motor below:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Cheers
Mar 8, 2010 at 8:07 AM
NUCRBOMB68
Thanks for this post. I had to get a new blower motor for $76.00, but it is all fixed. I love this site!
Oct 2, 2018 at 1:34 PM
MMEND
Please help, ac and heat fan will not turn on at all. Checked the relay and it is not the problem....We have to go home tomorrow which is a 10 hour drive home w/ no air...
Oct 3, 2018 at 11:43 AM (Merged)
Check the gauge fuse 10amp and the heater fuse 40amp if both okay-if heater relay is good-problem is coming from the blower switch or blower motor to include the ground behind right kick panel.
MMEND
Hi, sorry it took me awhile to get back. We did change the blower motor. But the air isn't blowing anough air. It's working now but not enough air, we have to put it up all the way before we can feel anything, Please help. thanks
[quote:c17429a5e8="rasmataz"]Check the gauge fuse 10amp and the heater fuse 40amp if both okay-if heater relay is good-problem is coming from the blower switch or blower motor to include the ground behind right kick panel.[/quote:c17429a5e8]
Check and test the blower blower resistor
MMEND
thanks
[quote:2f97512893="rasmataz"]Check and test the blower blower resistor[/quote:2f97512893]
VERONICA KOLCZYNSKI
I re placed blower motor but not resister it worked for two weeks quit again. what could be problem? could you tell me wh ere resister is located at? do you have a video to show how to test blower and how to put in resister and blower. or could it be something else?
  • 31,937 POSTS
Do you have any fan speeds at all?
VERONICA KOLCZYNSKI
it does nothing.
  • 31,937 POSTS
Check for voltage going into the fan motor when it is not working
VERONICA KOLCZYNSKI
its working again cleaned fuse its now working fine so far.
  • 31,937 POSTS
ok, that good to know.
