Mechanics
HEATER FAN NEEDS REPLACEMENT
1998 Toyota Corolla
Heater problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic
MY heater motor works fine, but the fan housing is broken and it needs replacement. How do I get to the fan to replace it? I assume I need to remove the dashboard, but have no idea on how to do that. Please advise.
Also, can you recommend a reliable, inexpensive vendors for quality replacement parts?
Dfolan
January 11, 2009.
The best approach is to use the car repair link in this thread or get a Haynes manual. This is a complicated sequence of removal, so an actual step by step procedure would be best.
Mmprince4000
Jan 12, 2009.
AD
