how to remove power steering belt?
1996 TOYOTA COROLLA
WANGZHE18
Steering problem 4 cyl Front Wheel Drive Automatic 89375 miles
I am trying to loosen power steering reservior in order to remove old belt for replacement. But there are one belt on the top and three belts at the bottom. Which two are pivot and lock bolts that I have to loosen please? Any help highly appreciated! Thank you.
Apr 14, 2009 at 5:45 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Here is a guide that will show you what you are in for when doing the job
https://www.2carpros.com/diagrams/toyota/corolla/1996
This can help as well.
https://www.2carpros.com/articles/replace-serpentine-belt
Cheers, Ken
Apr 14, 2009 at 10:37 PM
MMPRINCE4000
  • 8,548 POSTS
You have to loosen pivot bolt and the PS mounting bolt at base of PS unit, it can be hard to get to, remove RF tire and stone guard for better view.
Apr 15, 2009 at 6:25 AM
WANGZHE18
Thanks for your help! It's 1.6L, and your uploaded picture is a view of the generator. What I have no clue is the pivot and mounting/lock bolts for the power steering pump. There are about 4 or 5 bolts on the back of the P/S pump, and I don't know which ones to loosen. Any more help highly appreciated!
Apr 15, 2009 at 7:11 AM
WANGZHE18
Thanks for the help, mmprince! Which one are the pivot the PS mountin bolt please? There are several back there, and I don't know how to identify. Million thanks!
[quote:0c0ebb7202="mmprince4000"]You have to loosen pivot bolt and the PS mounting bolt at base of PS unit, it can be hard to get to, remove RF tire and stone guard for better view.[/quote:0c0ebb7202]
Apr 15, 2009 at 7:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_1_47.jpg
Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup-similar to alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt and then tighten the lock bolt.
Apr 15, 2009 at 10:30 AM
WANGZHE18
Thank you all for your answers and help! Really appreciated!
Apr 15, 2009 at 3:52 PM
DAVIDTHEBMXER
  • 19 POSTS
when I start the car there is a squeel then when I put it into gear it turns into a louder higher pitched chirp. I just changed the alternator beltt and the belt is tight. The squeel stops once the car is warmed up.
Feb 17, 2018 at 1:37 PM (Merged)
HMAC300
  • 48,601 POSTS
if you replaced the belt you should have replaced the tensioner spray water on belt and if noise goes away replace tensioner
DAVIDTHEBMXER
  • 19 POSTS
The alternator is used to tighten the tension, this car doesnt have regular tensioners.
HMAC300
  • 48,601 POSTS
then put a belt tension gauge on the belt and see if it's tight enough.
2CP-ARCHIVES
  • 4,540 POSTS
How to change a 1.8 liter engine power steering belt?
or how to tighten?
KHLOW2008
  • 41,814 POSTS
Loosen the pump bolt and pull at belt to get the belt to slacken for removal.
Reverse procedure for installation and retighten pump bolt after getting correctbelt tension.
PATRICK FRY
Steering problem
1994 Toyota Corolla 4 cyl Front Wheel Drive 180000 miles
Is it feasable to replace a broken power steering belt on my car if I am somewhat mechanically inclined? I have worked on my Ford truck so I am better with American cars. Or should I just head to a service station? Is this a job that can be done in my driveway?
  • 31,937 POSTS
Hi there,
It is possible to replace it in the drive way, you will have to jack it up and remove the wheel, as this will make the access to the pump bolts easier, have a go you should be ok with this.
mark (mhpautos)
HENRY BAGASAN
I want to replace the steering belt because of squeaking sound & found out that it is already sliding when I turned the wheel to the fullest right & left, do you have a video of how to replace it?
  • 54,350 POSTS
Hey HENRY
That is not to bad of a job, here is a diagram that will show you what you are in for.
https://www.2carpros.com/diagrams/toyota/corolla/1994
Please let us know happens so it will help others.
Best, Ken
DEEPBLUESEA1226
  • 7 POSTS
Engine Mechanical problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic 90000 miles
I want to know what is the easiest way to change the belt with air condition unit by myself. Please show me the way to change it.
thankyou very much
MMPRINCE4000
  • 8,548 POSTS
Move tensioner pulley (arrow in picture) to release tension on belt, then remove belt. Buy a good belt, Dayco, Gates, Goodyear, Toyota. Use brake clean to remove any contamination from pulleys, make sure pulleys are tracking properly.
https://images.2carpros.com/forum/automotive_pictures/108325_belt_routing_corolla_2.jpg
DEEPBLUESEA1226
  • 7 POSTS
I found the tensioner pulley, but I couldn't push it down like the photo shown. do I need some tool too release the tension?
Feb 17, 2018 at 1:38 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
A tensioner tool is available from most autoparts stores for rental.
Try a socket on a long ratchet.
DEEPBLUESEA1226
  • 7 POSTS
thank you guys.. I finally got the belt out.
MMPRINCE4000
  • 8,548 POSTS
Great news.
Make sure to inspect pulleys and clean with brake clean. Brake clean dissolves grease, grime, coolant and leaves no residue.
SKEEZIK
Steering problem
1994 Toyota Corolla 4 cyl Front Wheel Drive Automatic 112,00 miles
How do you replace the Power Steering Belt on a 1994 Toyota Corolla? I see one bolt that holds the power steering pump to a bracket and I loosened it but the pump didnt move. HELP.....
MMPRINCE4000
  • 8,548 POSTS
The bolt allows the pump to pivot, but you must loosen the base bolt ( the bolt that holds the pump at the bottom) to allow it to pivot, then replace belt, adjust tension, tighten pivot bolt, then base bolt.
OMGVTEC90
im having a similar problem i got my pulley loose but it wont move so i cant get my new belt on.. what should i try
GULF81STAR
1998 Toyota Corolla 4 cyl Front Wheel Drive Automatic 135000 miles
How do you go about replacing the serpentine belt on a Corolla?l
KHLOW2008
  • 41,814 POSTS
Hi gulf81star, The Auto tensioner has a 19 mm hex head which you can use to release the tension to remove the belt.
https://images.2carpros.com/forum/automotive_pictures/192750_SerpentineToyota98_1.jpg
