Hello my name is Tim and i'm from Alabama i currently have a 1995 Toyota Corolla with 220,000 miles and just recently got it out of the shop.Items that were repaired are: timing chain,waterpump,brand new fuel tank, and driver side door handles(inside&out).I noticed while driving my car the Engine Oil Pressure Warning Light was flickering on and off and there were also long periods at times when it did not flicker untill i hit a bump in the road or stomped my brakes.I stopped and checked the oil several times and it showed to be full on the dip-stick.After doing this i parked my car for a few minutes and as i began to crank my car back up the Engine Oil Pressure Warning Light flickered again briefly but as i traveled down the road it started the flickering again as before.Could this be serious or just a bad bulb or and open circuit in the electrical system?
Nov 9, 2008 at 9:57 PM
